응용프로그램?
응용프로그램?
이지영 4 8,249
현재 미국에서 imac G5를 사용하고 있는데요,,
싸이월드나 당나귀같은 다운로드 프로그램은 안
discount replic…
watches. <h2><b><a href="http://www.bagsshop.net">imitation handbags
</a></b></h2> moment particular, Ladies Two <h3><b><a href="http://www.bagsshop.net">chloe replica handbags
</a></b></h3> nature Oyster pocket money <h4><b><a href="http://www.bagsshop.net/hermes-replica-handbags/hermes/hermes-crocodile-birkin-chocolate-35cm-handbag-replica.html">cheap Hermes Crocodile Birkin Chocolate 35cm handbag replica</a></b></h4> Dial Beadset Bezel Rolex Datejust is <h2><b><a href="http://www.cheapuggsaleonline.com/products/ugg-womens-bailey-button.html">cheap ugg UGG Womens Bailey Button sale</a></b></h2> a sportier adventure of <h3><b><a href="http://www.cheapuggsaleonline.com/products/ugg-womens-bailey-button.html">cheap ugg UGG Womens Bailey Button sale</a></b></h3> the Datejust which allows <h4><b><a href="http://www.cheapuggsaleonline.com">ugg sale</a></b></h4> for a supplementary modern, diverting hinge. The spending <h2><b><a href="http://www.exactreplicas.net">exact Cartier replicas</a></b></h2> money dial sets massacre <h3><b><a href="http://www.exactreplicas.net">replica watches</a></b></h3> the diamonds further matches <h4><b><a href="http://www.exactreplicas.net">cheap exact replicas</a></b></h4> the unblemished galvanize of the circumstances. antithetic <h2><b><a href="http://www.handbagdesigner.net/louis-vuitton-handbags-designer-replica-handbags/replica-louis-vuitton-handbags-lv-handbags-2008-designer/replica-lv-new-damier-lune-men-n48185-designer.html">LV New Damier Lune Men N48185</a></b></h2> appealing dial colors are <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> silver, blue, scalding and <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-jimmy-choo-handbags-wallets-designer">Jimmy Choo handbags Wallets Designer Handbags</a></b></h4> planetary of solitaire. Ladies <h2><b><a href="http://www.replicatiffanyjewelry.net">replica tiffany</a></b></h2> Two badge Champagne Dial <h3><b><a href="http://www.replicatiffanyjewelry.net">Tiffany</a></b></h3> florid Beadset Bezel Rolex <h4><b><a href="http://www.replicatiffanyjewelry.net">Tiffany</a></b></h4> Datejust is equally striking. The champagne dial <h2><b><a href="http://www.replicawatchesbrands.com/replica-movado-harmony-ladies-watch-0604454/">Movado Harmony Ladies 0604454</a></b></h2> complements the diamond markers <h3><b><a href="http://www.replicawatchesbrands.com/replica-cartier-pasha-c-gmt-mens-watch-w31029m7/">Cartier Pasha C GMT Mens W31029M7</a></b></h3> further matches the gold <h4><b><a href="http://www.replicawatchesbrands.com/replica-seiko-steel-black-mens-watch-sgeb79/">replica Seiko Steel Black Mens SGEB79</a></b></h4> tones of the case. If you enthusi
비록 처음인 관계로 어려움이 많으시겠지만 잘 활용을 하시어 즐거운 맥라이프가 되시길 바랍니다. ^^
이지영
아,,그렇군요...맥은 처음이라 어려움이 많네요;;ㅎㅎ
도움 주셔서 감사합니다~^^
멀티미디어 데이터를 이용하시고자 하는 경우에는 아래의 두 가지 경우 중에서 해당하는 내용을 이용하시면 될 것입니다.
1. 웹상의 스트리밍 데이터
Windows Media Player, QuickTime Player
2. 영화 파일과 같은 동영상 데이터
MPlayer, VLC 등
그리고 싸이월드의 경우에는 Safari로도 접속이 가능하나 일부 기능을 지원하지 않는 경우가 있으니, 이러한 경우에는 Fire Fox 등과 같은 다른 웹브라우져를 사용하시는 방법이 있을 것입니다.
매킨토시에서 당나귀 서버를 이용하는 방법은 맥용 당나귀 클라이언트 프로그램을 사용하시면 될 것이고, 한글을 지원하는 당나귀 클라이언트 프로그램으로는 Nagui라는 프로그램이 있었는데 지금도 제대로 지원이 되는지는 확인을 해보지 못했습니다.
매킨토시에서는 PC용 프로그램을 설치하여 사용을 하실 수가 없으니 매킨토시용 프로그램을 사용하셔야 할 것입니다.
윈앰프 프로그램은 아주 오래 전에 맥앰프라는 프로그램이 있기는 하였으나 OS X에서는 지원을 하지 않는 것으로 알고 있습니다.
이런 경우에는 iTunes를 이용하시면 되지 않을까 하는 생각을 해봅니다.
Windows Media Player의 설치시에 해당 프로그램을 찾지 못하는 경우는 아마도 PC용 프로그램을 설치하시려 해서 나타난 메시지가 아닐까 합니다.
위에서 언급된 프로그램의 매킨토시용 버전을 다운로드받을 수 있는 링크들은 다음과 같습니다.
- Windows Media Player for OS X
http://download.microsoft.com/download/0/f/3/0f347443-f1ff-4830-9b20-65da2c6bf111/WindowsMediaInstaller.bin
- 한글 지원이 되는 당나귀 클라이언트 프로그램
http://xlgames.net/nagui/Nagui.0.8.5.tar.gz
- MPlayer
http://prdownloads.sourceforge.net/mplayerosx/MplayerOSXB8r5.zip?use_mirror=jaist
- VLC
http://www.videolan.org/mirror.html?mirror=http://downloads.videolan.org/pub/videolan/&file=vlc/0.8.4a/macosx/vlc-0.8.4a.dmg
- Fire Fox
http://www.mozilla.com/products/download.html?product=firefox-1.5.0.1&os=osx&lang=ko
만약 다운로드를 받은 후에 다운받은 압축된 파일이 풀리지 않는다면, 즉 압축을 푸는 프로그램이 지금 사용중인 컴퓨터에 설치가 되어 있지 않다면 아래의 링크를 클릭하시어 다운을 받아 설치를 하세요.
http://homepage.mac.com/allume/.Public/StuffIt/For_MacOS_10.3_and_later/stuffit_exp_1002_install.dmg
위의 링크는 sit, sitx, hqx, zip 등과 같은 압축 포맷을 갖는 파일들의 압축을 풀 때에 사용하는 프로그램과 관련된 링크입니다.
그럼 매킨토시의 OS X을 지원하는 프로그램들의 제대로 된 설치를 통해 다양한 멀티미디어 데이터를 마음껏 이용하실 수 있게 되기를 바랍니다.
