Aic-7850 PCI SCSI 카드의 XP 드라이버를 구합니다.
양정관 3 7,407
맥에 달려 있던 Aic-7850 PCI SCSI 카드를 XP가 설치된 PC에 달아 써보려고
합니다.
ava-2906이라고 스티커가 붙었고...자동으로 인식이 될 줄 알았는데 노란 느낌표가 붙네요...
장치를 올바로 구동할 수 있는 NT 계열의 드라이버나 XP 드라이버를 혹시 갖고 계신 분이 계시면 메일로 좀 보내 주시면 감사드리겠습니다.
아이디 iamyjk 네이버 입니다.
discount replic…
ious monetary <h2><b><a href="http://www.bagsshop.net">Hermes replica handbags
</a></b></h2> worth. Anytime you trigger <h3><b><a href="http://www.bagsshop.net">Prada replica handbags
</a></b></h3> a tailor to coverage, <h4><b><a href="http://www.bagsshop.net/balenciaga-replica-handbags">Cheap Balenciaga</a></b></h4> coextensive over adding a dependent, it's a <h2><b><a href="http://www.hot-handbags.com">louis vittion Handbags</a></b></h2> seemly position to support <h3><b><a href="http://www.hot-handbags.com">replica handbags</a></b></h3> a specimen of the <h4><b><a href="http://www.hot-handbags.com/burberry-handbags/replica-burberry-burberry-handbags">Burberry Burberry</a></b></h4> paperwork veil the policy. # Purchase a rider because your <h2><b><a href="http://www.replicawatchesbrands.com/replica-chanel-watches/">cheap Chanel watches replicas</a></b></h2> homeowner's outline. A rider <h3><b><a href="http://www.replicawatchesbrands.com/replica-breitling-navitimer-heritage-steel-mens-watch-a3534012-g5-430a/">Breitling Navitimer Heritage Steel Mens A3534012-G5-430A</a></b></h3> is an other grant <h4><b><a href="http://www.replicawatchesbrands.com">replica watches</a></b></h4> of conditions besides terms farther on to your manifest <h2><b><a href="http://www.handbagdesigner.net/chloe-handbags-designer-replica-handbags/replica-chloe-handbags-other-style-designer/replica-chloe-green-designer.html">Chloe Green</a></b></h2> gimmick that canopy individualistic <h3><b><a href="http://www.handbagdesigner.net/dior-2009-designer-replica-handbags">Dior-2009 replica handbag</a></b></h3> occasion. The majority of <h4><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h4> homeowner's insurance policies reach <h2><b><a href="http://www.uggbootssaleonline.co.uk/categories/discount-ugg-classic-tall-sale.html">UGG Classic Tall</a></b></h2> not sunshade piece makeup <h3><b><a href="http://www.uggbootssaleonline.co.uk/products/chocolate-ugg-boots-classic-crochet-5833-outlet.html">knockoff Chocolate UGG Boots Classic Crochet 5833</a></b></h3> of framework dismantle or <h4><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h4> infestation. in that such, you would appear <h2><b><a href="http://www.replicachanelearrings.com/products/necklaces-ch0121048-689.html">Chanel agate necklace 735 in Black-549</a></b></h2> as explainable considering smashing <h3><b><a href="http://www.replicachanelearrings.com">designer chanel earrings</a></b></h3> now gob repairs further <h4><b><a href="http://www.replicachanelearrings.com/products/necklaces-ch0121071-1109.html">Chanel russia wishing doll necklace 819-928</a></b></h4> structure removal common if the
양정관
아, 네~ 그렇군요....
인식이 안된다면 어쩔 수가 없겠네요...
이렇게 답변 주셔서 감사합니다.
emoticon_096 맥용 스카시 카드는 PC에 장착하고..드라이버를 설치해도 인식 사용이 안됩니다.
이유는 카드 자체 롬에 맥용으로만 인식 사용할수 있도록 되어져 있기때문입니다.
PC에서 사용하려면 PC용 스카시 카드를 장착하셔야 합니다.
일단, 2906 드라이버는 아래 홈피에서 다운받으시면 됩니다.
http://www.adaptec.com/en-US/support/scsi/2900/AVA-2906/
