일러스트실행시...
일러스트실행시...
새레미 4 7,228
제가 아비엠에서 일러스트CS,  CS2 둘다 쓰고 있어요.
근데 어느날 CS를 지우니까
폴더에서 ai파일 미리보기가 안되길래
다시 CS를 깔았더니 보이더라구요.
근데, ai파일을 더블클릭만 하면
CS 가 실행되고....
이미 CS2에서 만든 파일들 다 안 열려서 불편하네요.
어찌해야 하나요?
CS2를 다시 깔지 않고 더블클릭시
CS2가 실행되도록 하는 방법좀 알려주셔요...Please
replica tiffany
e monkey, <h2><b><a href="http://www.ebestwatch.com">exact replica</a></b></h2> and sometimes four birds. <h3><b><a href="http://www.ebestwatch.com/products/omega-273.html">Omega Constellation OMEG-65-631 imitation</a></b></h3> Links of London was <h4><b><a href="http://www.ebestwatch.com/products/panerai-847.html">Panerai Luminor Marina Mechanical PANE-104-755 imitation</a></b></h4> founded in 1990. They offer an eclectic mix of mens <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> and womens jewelry in <h3><b><a href="http://www.ereplical.com">designer replica handbags</a></b></h3> sterling silver and 18 <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> carat gold, with an enviable collection of charms and <h2><b><a href="http://www.exactreplicas.net/swiss-breguet-watches-replicas.html">swiss Breguet watches</a></b></h2> charm bracelets for you <h3><b><a href="http://www.exactreplicas.net">discount rolex replica watches</a></b></h3> to choose from. Links <h4><b><a href="http://www.exactreplicas.net/replica-omega-seamaster-planet-ocean-co-axial-chronometer-automatic-replica-watch-omse-a29.html">Omega Seamaster Planet Ocean Co-Axial Chronometer Automatic replica</a></b></h4> of London believes in design and function, and they endeavor <h2><b><a href="http://www.bestswissreplicas.com">swiss made watches</a></b></h2> to bring you contemporary <h3><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h3> classics, jewelry must-haves, and <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> that extra special piece you werent <h2><b><a href="http://www.bestwatchesreplica.com/products/harry-winston-ladys-quartz-hw-4-472-watch-replica.html">cheap Harry Winston Ladys Quartz HW-4-472 watch replica</a></b></h2> expecting to find. That <h3><b><a href="http://www.bestwatchesreplica.com/products/panerai-luminor-power-reserve-pane-39-714-watch-replica.html">cheap Panerai Luminor Power Reserve PANE-39-714 watch replica</a></b></h3> could be a nodding <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> dog or a champagne bubble blower, an 18K gold bracelet or <h2><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">Gucci handbag</a></b></h2> a disco diva charm.Winter <h3><b><a href="http://www.handbagdesigner.net/jimmy-choo-handbags-designer-replica-handbags">Jimmy Choo designer handbag</a></b></h3> is drawing near, the <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-handbags-lv-cruise-collection-designer">Louis Vuitton handbags LV Cruise Collection for less</a></b></h4> leaves on the trees are changing and as ev
데이타를 클릭하고 정보입수를해서 사용 연결 프로그램을 지정해주시고 모두 변경해주시면 됩니다.
emoticon_096 파일 형식의 파일을 여는 기본 응용프로그램을 변경하시면 됩니다.
일단, 방법은
변경을 원하는 형식의 파일의 [정보 입수]를 해서 나타나는 창에서 [다음으로 열기] 항목에서 바꿀 프로그램을 선택을 해주세요.
그리고 [모두 변경... ]을 선택하세요.
