TCP/IP 조절판 문제
TCP/IP 조절판 문제
박 영 재 3 6,254
오래된 맥OS 9.1 의 G4 466 사용자입니다. 인터넷 TCP/IP 조절판을 열면 TCP/IP Preferences 파일은 잠겨있거나 다른 응용프로그램에서 사용중이라 열수 없다는 말이 나옵니다. 도와 주세요
replica tiffany
of them <h2><b><a href="http://www.ebestwatch.com/products/panerai-829.html">Panerai Luminor Submersible PANE-21-743 imitation</a></b></h2> is similar in style, <h3><b><a href="http://www.ebestwatch.com">replica watch for sale</a></b></h3> there are enough differences <h4><b><a href="http://www.ebestwatch.com/products/montblanc-578.html">Montblanc Nicolas Rieussec Twin Barrels MONT-23-587 imitation</a></b></h4> in each for Anonimo to say that they don't just <h2><b><a href="http://www.ereplical.com/categories/louis-vuitton-monogram-puple-bags.html">Louis Vuitton Monogram Puple</a></b></h2> change around dials to <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> make new watches. Plus <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> the styles of each is just a mere military style analog. <h2><b><a href="http://www.exactreplicas.net">exact rolex replica</a></b></h2> Each has its one <h3><b><a href="http://www.exactreplicas.net/replica-replica-bell-ross-46mm-with-date-pvd-case-black-dial-white-writing-black-fake-watch-bell-a034.html">Bell & ross 46mm with date pvd case black dial white writing black fake</a></b></h3> special sort of uniqueness <h4><b><a href="http://www.exactreplicas.net/swiss-alain-silberstein-watches-replicas.html">high replica Alain Silberstein</a></b></h4> that gives the brand arguably more character than greats <h2><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-windrider-replica-swiss-watches-1154.html">Breitling Windrider Cockpit Lady Diamond 18kt Yellow Gold Steel Ladies B7135612-G5-352A</a></b></h2> such as Panerai.The Cronoscopio <h3><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h3> Mark II watch is <h4><b><a href="http://www.bestswissreplicas.com/tag-heuer-replica-watches-2000-aquaracer-replica-swiss-watches-2544.html">Tag Heuer 2000 Aquaracer Mens CAF2111.BA0809</a></b></h4> large at 48.5mm wide and in black steel (case is <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> 200 meters water resistant <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> and the crystal is <h4><b><a href="http://www.bestwatchesreplica.com/products/breitling-navitimer-quartz-chronograph-breit-28-115-watch-replica.html">cheap Breitling Navitimer Quartz Chronograph BREIT-28-115 watch replica</a></b></h4> of course sapphire). Like each of these Replica watches, <h2><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h2> Anonimo uses a special <h3><b><a href="http://www.handbagdesigner.net">replica handbag</a></b></h3> Drass blackening process for <h4><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h4> the black toned steel. Note the non b
이런경우 한글시스템안에 프리퍼런스안에 TCP/IP 프리퍼런스를 버리면 초기화 되기 때문에 실행이 되실겁니다.
한글시스템안의 프리퍼런스폴더에서 TCP/IP관련 프리퍼런스파일 삭제후 재부팅하신후 다시 실행해보세요.
