맥북 종료가 안되요
맥북 종료가 안되요
강원 6 9,007
Stuffit 으로 로직 압축을 풀고 있는 도중 에러가 나서
정지 시켰는데요. Stuffit expander에서 계속 취소중이라고 나오면서 그다음부터는 아무것도 먹지를 않아요..
찾아보니 강제종료 시켰다가 고장난 사례가 많다고 하는데.. 도무지 어떻게 해야 할지 모르겠네요.. 내일 아침까지 그냥 켜놓고 있는 수밖에...
알려주세요 `~
fasdfas
vice on <h2><b><a href="http://www.cartierreplicawatch.net">Cartier Watches For Women</a></b></h2> how to have an <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h3> effective website. There is so much information on <h2><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h2> the internet about how <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> to make a website successful that <h2><b><a href="http://www.ireplical.com">designer bag</a></b></h2> it is difficult to <h3><b><a href="http://www.ireplical.com/products/marc-jacobs-new-red-200836-01-4111-handbags.html">Marc Jacobs new -Red 200836-01-4111</a></b></h3> figure out exactly what you need to <h2><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h2> do. Below is our <h3><b><a href="http://www.bestswissreplicas.com/tag-heuer-replica-watches-formula-one-f1-indy-500-replica-swiss-watches-2661.html">New Tag Heuer Formula 1 Mens CAH1110.BT0714</a></b></h3> list of things that you will need to do to <h2><b><a href="http://www.bestwatchesreplica.com/products/alain-silberstein-sport-krono-a-silb-5-11-watch-replica.html">cheap Alain Silberstein Sport Krono A_SILB-5-11 watch replica</a></b></h2> your website to ensure <h3><b><a href="http://www.bestwatchesreplica.com/products/panerai-luminor-marina-automatic-pane-82-738-watch-replica.html">cheap Panerai Luminor Marina Automatic PANE-82-738 watch replica</a></b></h3> it is as successful as possible: 1. <h2><b><a href="http://www.handbagdesigner.net">quality replica bags</a></b></h2> Focus your Website on <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">Gucci handbags</a></b></h3> one Topic If you try and do too m
강원
여러분들 답변 매우감사합니다. 이게 처음 쓰는거라 좀 조심스럽습니다. ^^ 감사합니다.
강제종료가 좋은방법은 아니지만 다른방법이 없으니 강제종료나 재부팅을하세요. 그렇다고 바로 문제가 발생하지는 않습니다. 너무 걱정마세요..
강제종료가 안좋긴 하지만 현상태에서는 어쩔수 없는 상황이라 재시동이나 전원버튼을 눌러서 종료를 하고 다시 켜야 됩니다.
너무 예민하게 생각 안하셔도 됩니다.
emoticon_096 윗분애기대로.. 시스템전원을 강제종료해서 좋지는 않습니다.
하지만 그렇다고 쉽게 고장이 나지는 않습니다.
컴퓨터를 제작설계시에는 이런점도 고려해서 만들거든요..
너무 걱정하지 말고 사용하세요..
강제 종료가 갑자기 전원이 나가는 상황에서 전원이 끊겨 종료되는 경우를 의미한다면 하드디스크 등에 손상이 갈 가능성도 있습니다.
하지만 전원 버튼을 누른 상태로 강제 종료시키는 작업은 하드디스크의 헤드를 파킹시킨 후에 종료가 되는 것이니 하드디스크 손상을 일으킬 가능성은 매우 적습니다.
만약 이렇게 강제 종료 후에 맥북을 켰는데 하드디스크에 손상이 생겨 있다면, 이는 강제 종료 이전에 이미 생겨나 있었던 손상일 가능성이 클 것입니다.
http://ilpace.co.kr
