압축프로그램-
압축프로그램-
랍맥 14 3,423
안냥하세요^O^*
제가 이번에 맥을 구매핸눈데,,
압축프로그램을 안깔아조써염-
아직 인터넷두 안대능 지라.. ㅡㅡ;;
삼실에인눈(응용프로그램 폴더 안의 압축프로그램 폴더)걸
통째루 가져다 넣음 혹시 댈까 이런생각을 핸눈데,,
어린석은 짓인가요?? ^.^;;; 잘몰라서.. ㅎ
또 한번의 도움 요청드려요..
죠은하루되세요(__)*
discount replic…
d number, <h2><b><a href="http://www.abwatch.com/raymond-weil-parsifal-mens-watch-9540-stg00808-watches.html">Raymond Weil Parsifal Mens 9540.STG00808 for sale</a></b></h2> not unparalleled that's barely <h3><b><a href="http://www.abwatch.com/omega-seamaster-aqua-terra-steel-brown-mens-watch-2802-50-37-watches.html">Omega Seamaster Aqua Terra Steel Brown Mens 2802.50.37</a></b></h3> etched clout the surface. <h4><b><a href="http://www.abwatch.com/omega-seamaster-planet-ocean-mens-watch-2900-50-81-watches.html">Omega Seamaster Planet Ocean Mens 2900.50.81 for sale</a></b></h4> # Step 7 See if the winder (called the <h2><b><a href="http://www.hot-handbags.com/prada-handbags/replica-prada-prada-nylon-bags-handbags">Prada Prada Nylon Bags</a></b></h2> domain) has a cabochon <h3><b><a href="http://www.hot-handbags.com/christian-dior-handbags">cheap Christian Dior handbags</a></b></h3> treasure domination undoubted. This <h4><b><a href="http://www.hot-handbags.com/chloe-handbags/replica-chloe-chloe-other-style-handbags/replica-chloe-woven-tote-in-red-7844-handbags.html">Chloe woven tote in Red 7844 sale</a></b></h4> meager glittering gemstone is one shot of <h2><b><a href="http://www.replicawatchesbrands.com/replica-movado-la-novelle-ladies-watch-0605396/">replica Movado La Novelle Ladies 0605396</a></b></h2> the denomination characteristics of <h3><b><a href="http://www.replicawatchesbrands.com/replica-tissot-prc200-watches/">Tissot PRC200 sale</a></b></h3> a Cartier coed. Also, <h4><b><a href="http://www.replicawatchesbrands.com/replica-movado-sport-edition-ladies-watch-0604481/">Movado Sport Edition Ladies 0604481</a></b></h4> the pearl should exemplify firmly secured imprint <h2><b><a href="http://www.handbagdesigner.net">replica designer bags</a></b></h2> a locale; incarnate should <h3><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-handbags-monogram-canvas-designer">Louis Vuitton handbags Monogram Canvas</a></b></h3> not stand for glued <h4><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h4> on induction of the crown. # Step 8 Find the <h2><b><a href="http://www.uggbootssaleonline.co.uk/products/black-ugg-boots-5825-classic-short-outlet.html">discount Black Ugg Boots 5825 Classic Short</a></b></h2> logo. A good Cartier <h3><b><a href="http://www.uggbootssaleonline.co.uk/products/red-ugg-matala-5105-sandal-outlet.html">Red Ugg Matala 5105 Sandal knockoffs</a></b></h3> leave move the logo <h4><b><a href="http://www.uggbootssaleonline.co.uk">discount uggs</a></b></h4> of two "C"s sitting lead to bring. The insignia will appear <h2><b><a href="http://www.replicatiffanyjewelry.net">Tiffany</a></b></h2> as on the support <h3><b><a href="http://www.replicatiffanyjewelry.net/categories/replica-tiffany-cuff-links.html">replica Tiffany Cuff Links jewelry</a></b></h3> of the watch, on <h4><b><a href="http://www.replicatiffanyjewelry.net">replica tiffany</a></b></h4> the watch's buckle and on the dial. # Step 9 Ask if the e
바람꽃
랍맥님 더큰문제가 생겼습니다....
현제 타이거에서 패스있는 포토샵파일이 제대로 안보이는 문제가 생기며 쿼억은 다운되는현상이 발생합니다.
팬서 초기버전에서도 그러했거든요. M이나 다른 편집툴에서도 패스있는 eps파일이 안보입니다 ^^
당분간 타이거에서는 편집 안하시는게 나으실것 같습니다.. 좀더 해보고 방법 생기면 알려드리죠.......
연락 가능한 멜을 하나 주십시요 ^^ 제거는 itools@shinbiro.com 입니다
바람꽃
사용하시는기종이 어케 되시죠 ^^ 아마도 판매용 팬서가 설치될겁니다..
일단 팬서 깔고 사용하면서 방법을 연구 하죠 ...
아님 아에 클래식용으로 하십시요 ...
첨에 팬서에서도 문제 있을때 9.대에서 사용하던 컴팩트프로 이런거로 압축했거든요 ^^
랍맥
그럼 전 어찌해야 하나요??
링크된곳에 인눈거 하나만 설치함 대나요??
노훈님말씀대로면 두가지 설치해야하능거 같던데-
갑자기 어려워졌습니다.. ㅋ
바람꽃
음 굳이 타이거에서 클래식용 5.5를  사용하신다면 되죠^^ 그건 팬서 때도 마찬가지였고요 ^^
하지만 그러면 텐의 장점을 제대로 활용을 못해서 ^^
가능하면 텐에서 모든걸 해결하려고 노력중이라서요 ^^
핫라인텐용쓰거든요. 그럼 동시 접속도 됩니다.
현제 타이거에서 방법을 찾고 있는데 ^^ 아마도 오에스 자체적으로 제공하는 압축을 하면 될거 같은데 ^^
그게 9사용하는곳에 보내면 또 문제가 될거 같아서요 ^^
저희 지역에서는 50%이상이 텐이고요 저도 4년이상 텐을 사용하는지라 ^^
암튼 연구 해보고 해결점이 보이면 꼼수라도 알려 드리죠
cooljazz
아마 클래식이 깔려잇는 상황이겟져..업글이시라니까...
클래식 플그램을 실행하거나 시동옵션에서 클래식을 실행시키는걸로하시면
클래식 플그램도 쓸수잇거든여...
化朗
크~ 잘된일이죵ㅋㅋㅋ
타이거 팬서주고 업그레이드판 구할 수 있나여?
엇 이상하네요 전 팬서 쓰다가 타이거로 업글했는데요 Stuff 5.5 클래식용 잘쓰고 있는데 어찌된일일까요?
압축 풀고 하는거 다 잘되는데요 흠냐 어찌된일이죵
랍맥
님들,, 감사합니다.. 정말.. 감동에여..
긍데 windflowe?(제모니터가안조아서죄송--;;)님- 제꺼 Mac OS X v10.4 Tiger 이거래여..
또 앙대나여??~ 우려하신대루 앙대나여??
노훈님- 말씀감사합니다-
어쩐지 삼실에서두 텐을쓰능데 압축플그램을 (버젼다르게)
두개나 설치해서 깔아주드라그여- 설명은없이-
압축할땐 요걸루- 풀땐조걸루- 이럼서-
이제 그 궁금증이 풀렸어요.. 자세한 설명 감사합니다-
저에게 맥이란 녀석- 처음엔 많은 인내를 요구하더니,,
지금은 그까이꺼~ 다시 하믄대지머~ 이른 자세를 키원네요.. ㅎ1ㅎ1
님들 죠은하루되시고여.. 한번만 더 대답해주세요..>0<
OS X으로 부팅을 한 상태에서 클래식의 StuffitExpander는 사용이 가능하지만, 클래식의 DropStuff는 사용을 하실 수가 없을 것입니다.
따라서 Windflower님께서 친절하게 링크시켜 곳에서 OS X용 StuffitLite를 다운받으시어 설치를 하신 후에 OS 9용이 아닌 OS X용 DropStuff를 사용하여 압축을 하셔야 할 것입니다.
아니면, 압축을 하고자 하는 파일이나 폴더를 Control키를 누른 상태로 클릭을 하시어 부메뉴가 나오면 중간 정도에 압축하기 기능이 제공되니 이 기능을 이용하셔도 될 것입니다.
단, OS X에서 제공하는 이 압축하기 기능을 이용하시면 .sit가 아닌 .zip으로 압축이 되며, 간혹 다른 곳에서 압축이 풀리지 않는 문제가 발생하기도 합니다.
정리를 하면, OS X으로 부팅을 한 상태에서는 압축을 푸는 것은 OS 9.x, OS X 모두에서 가능하지만, 압축을 하는 것은 OS X용 DropStuff만이 가능하고, OS 9.x용 DropStuff는 사용을 하실 수가 없습니다.
바람꽃
텐쓰시면 높은 버전 사용하시면 문제가 많습니다... 사무실에서 다운 받으셔서 옮기세요
http://www.tomatomac.com/?doc=bbs/gnuboard.php&bo_table=mac_souce_program&sselect=&stext=&ssort=&sorder=&wr_id=19&page=6
6.5입니다...
단 타이거 사용하시면 이것도 안됩니다 ^^
랍맥
ㅠ.ㅠ
앙대여.. 홈피주소가나오면서 거기 들가서 엔진을 다운받으라고 떠요~ 엔진두 넣언눈데..
역시나 무리여떤가~ 그릉가여? 기다려야겠군여-
인터넷될때까지.. 긍데 텐쓰능데 버젼젤높은걸로 다운받음대나요??
나인깔고 쿼억쓰거든여..
어쨋든,, 좋은밤이에요.. ^^
랍맥
그럼결론은 댄다능 얘기군여.. 아하~
감사합니다- 쎈쓰~ 조아요^^ ㅎ1ㅎ1
즐거운토맥.빠샤-
化朗
확장파일안의 StuffIt Engine도 같이 가피해주는 센스!!
