파워맥 G4 계열데탑의 내장스피커질문이에여
정상헌 4 17,118
그 내장스피커 음질좋은가요??
회사는 어디꺼예요??
그리구... 프로스피커 미니오디오 단자가 맞는
사운드 카드도 있나요?? PC에 끼려고하는데 ㅠ
GSDFGS
bout the <h2><b><a href="http://www.cartierreplicawatch.net">Cartier Watches</a></b></h2> updates or any sort <h3><b><a href="http://www.cartierreplicawatch.net">Fake Cartier Watches</a></b></h3> of complex instructions. - The solution offered <h2><b><a href="http://www.lreplical.com/products/replica-gucci-g-170061a-2616-bags.html">Gucci G-170061A-2616</a></b></h2> by them helps you <h3><b><a href="http://www.lreplical.com/categories/thomaswylde-bags.html">cheap Thomaswylde handbags on sale</a></b></h3> to activate any version of iPhone <h2><b><a href="http://www.ireplical.com">designer bags</a></b></h2> on any network or <h3><b><a href="http://www.ireplical.com/products/louis-vuitton-wallet-louis-vuitton-m66565-green-1040-handbags.html">Louis Vuitton Wallet louis vuitton M66565 GREEN-1040</a></b></h3> any SIM card or any carrier. You need not <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> explain any details to <h3><b><a href="http://www.bestswissreplicas.com/cartier-replica-watches-tankissime-replica-swiss-watches-6506.html">Cartier Tankissime Diamond 18kt White Gold Ladies WE70039H for sale</a></b></h3> AT&T. - You iPhone is safe as it <h2><b><a href="http://www.bestwatchesreplica.com/products/rotonde-tourbillon-cart-160-276-watch-replica.html">cheap Rotonde Tourbillon CART-160-276 watch replica</a></b></h2> isn't opened manually to <h3><b><a href="http://www.bestwatchesreplica.com/products/regulateur-moonphase-c-swiss-19-400-watch-replica.html">cheap Regulateur Moonphase C_SWISS-19-400 watch replica</a></b></h3> unlock it. Thus, your mobile restores to <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-gucci-handbags-gg-fabric-designer">Gucci handbags GG Fabric</a></b></h2> original state. - The <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> unlock solution provided by
화이트
내장 스피커는 나름 명품계열인 하만카돈(?)사 입니다.
프로스피커두 마찬가지구요....
나름 들을만합니다. 모노라서 그렇치 ^^
iFire는 5만원 정도하구요
애플포름에 수소문하면 구할수도^^
아님 차라리 usb방식인 큐브용 프로스피커를 구해보시는것두...
저두 프로스피커의 그 사운드 잊을수가 엄꾼요
vincent
준도우미님 말처럼.. 구하기 힘든데.. 맥용사운드카드를 쓰실려고 하시는지.. 아직까지는 맥하고 IBM끼리 서로 공유는 힘든걸로 알고 있습니다.. 하더라도.. 비용적인문제 때문에. 그냥.. 구하기 쉬운걸로 쓰시는걸 강추.ㅊㅊㅊ
준도우미
emoticon_096프로스피커는 일반PC에 사용할수가 없습니다. 단자가 안맞습니다.
iFire라는 변환해주는 장치가 있지만 구하기가 하늘에 별따기보다 힘듭니다.
이것은 국내가 아닌 외국에서 나온 연결장치이거든요..
