파일 열기
파일 열기
랑호 3 2,706
이번에 하드를 바꾸면서 기존기본 한글시스템과 데이터는 남기고 os를 새로 설치했습니다.
그런데 전에 작업했었던......
퀵이나 일러 포토 파일을 열때 응용프로그램을 찾을수없다고 나오네요...ㅜ.ㅜ
일러먼저 실행하고 일러파일 열면 열리긴하는데 여간불편해서요...
멋진 답변 기다리겠습니다...^^
fadfa
are generally <h2><b><a href="http://www.cartierreplicawatch.net/breitling-aeromarine-colt-oceane-steel-black-ladies-watch-a7738011-b7-620-replica-cartier.html">Breitling Aeromarine Colt Oceane Steel Black Ladies A7738011-B7-620</a></b></h2> associated with the High <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watches</a></b></h3> Street Stores.  The UK jewellery <h2><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h2> market has a wide <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> range of product offering depending on <h2><b><a href="http://www.ireplical.com/products/coach-handbag-khaki-coaco-1443c-4459-handbags.html">Coach handbag Khaki COACO-1443C-4459</a></b></h2> the material used and <h3><b><a href="http://www.ireplical.com">replica designer handbags</a></b></h3> its price. Hand-made jewellery are <h2><b><a href="http://www.bestswissreplicas.com/a-lange-sohne-replica-watches-grand-lange-1-replica-swiss-watches-202.html">cheap A Lange & Sohne Grand Lange 1 Mens 115.026</a></b></h2> very famous in UK <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> and is used in fashion, costume ethnic and <h2><b><a href="http://www.bestwatchesreplica.com/products/patek-philippe-automatic-calendar-p-phil-115-810-watch-replica.html">cheap Patek Philippe Automatic Calendar P_PHIL-115-810 watch replica</a></b></h2> in imitation jewellery. The <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> fashion jewellery has varieties of <h2><b><a href="http://www.handbagdesigner.net/loewe-handbags-designer-replica-handbags">Loewe handbag</a></b></h2> wedding rings, bracelets, necklaces, <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">Gucci replica handbags</a></b></h3> toe rings, pe
랑호
우어 정말 감사합니다.
하늘아기
OS버전이 9.x시라면 데스크탑 재형성을 하시면 됩니다.
파인더 상에서 com+option+esc키를 누르시면 파인더 강제종료물음이 나옵니다.
그러면 com+option키를 누르신상태로 승인을 하시면 데스크탑 재형성메세지가 나옵니다.
승인을 누르셔서 데스크탑 재형성을 완료 하시면 시스템에서 응용프로그램을 알아서 인식하게 될겁니다.
ps.재형성도중 강제종료나 기타 다른작업은 하시면 안돼구요
