G4에서 CD가 안 읽혀서 교체가 필요한데요?
몬난이진빵 5 3,320
G4에서 CD가 읽히지 않아 CD-RW를 교체 해야 할꺼 같은데요?
어디서 사야 하나요? 그리고 교체는 해보지 않았는데....
잘 몰라도 제가 교체가 할수 있나요? 제주도인데...
수리를 해 주는데가 없네요...ㅜㅜ
그리고 어디서 구입을 해야 하는지....
콤보드라이브와 슈퍼드라이브 차이는 무엇인가요??
빠른 답변 부탁드려요...^^
vasdfased
c
ndition for <h2><b><a href="http://www.cartierreplicawatch.net/rado-ceramica-black-mens-watch-r21347162-replica-cartier.html">Rado Ceramica Black Mens R21347162</a></b></h2> seal products, and offer <h3><b><a href="http://www.cartierreplicawatch.net/cartier-tank-francaise-18kt-yellow-gold-and-steel-mens-watch-w51005q4-replica-cartier.html">Cartier Tank Francaise 18kt Yellow Gold and Steel Mens W51005Q4</a></b></h3> friction-reducing ingredients. If <h2><b><a href="http://www.lreplical.com">designer replica leather handbags</a></b></h2> you are concerned about <h3><b><a href="http://www.lreplical.com/products/replica-gucci-hobo-in-black-leather-g169956a-2248-bags.html">Gucci hobo in black leather G169956A-2248</a></b></h3> the environment, avoid products with <h2><b><a href="http://www.ireplical.com">designer bags</a></b></h2> resin or PTFE Teflon <h3><b><a href="http://www.ireplical.com/products/gucci-g191719rd-2562-handbags.html">Gucci G191719RD-2562</a></b></h3> ? to help protect the ozone layer. <h2><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-professional-replica-swiss-watches-1069.html">Discount Breitling Professional B-1 Steel Grey Mens A7836238</a></b></h2> Often doctors need to <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> explain certain medical concepts to <h2><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h2> their patients, which can <h3><b><a href="http://www.bestwatchesreplica.com/products/breitling-longitude-quartz-chronometer-breit-165-171-watch-replica.html">cheap Breitling Longitude Quartz Chronometer BREIT-165-171 watch replica</a></b></h3> be very tough as the patients may <h2><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">designer Gucci replica handbags</a></b></h2> not know about the <h3><b><a href="http://www.handbagdesigner.net/new-dior-handbags-designer-replica-handbags">NEW Dior</a></b></h3> details of the human body, medical
소니, 엘지 등의 제품들은 대부분 호환에 문제가 없습니다.
하지만 간혹 호환에 문제가 되는 모델들이 일부 있기도 합니다.
따라서 저희는 매킨토시와 호환에 아무런 문제가 없는 특정 제품만을 취급하고 있으니 연락(02-2277-7287)를 주시면 CD-RW, Combo Drive, Super Drive에 대한 설명이나 호환에 문제가 없는 제품들의 가격도 확인을 하실 수가 있을 것입니다.
그리고 어디서 구입을 하시든 교체 작업은 그리 어렵지 않으며, 전화를 통해서도 설명이 가능하답니다.
다시 말씀을 드리면 소니, 엘지 등의 제품은 거의 호환에 문제가 없을 것이나, 아주 일부 모델만이 호환에 문제가 있는 경우가 있으므로 대부분은 큰 문제없이 사용이 가능한 것으로 보셔도 될 것입니다.
몬난이진빵
PC랑 같이 쓴다고 해서 알아봤는데요....
맥이랑 같이 쓰는 CD-RW는 없어서...
CD를 읽기만 가능하고 굽는건 안된다고 하는데....
도대체 어떤 제품을 사야 하는데 상표를 말씀해 주시면 안되나요??
몬난이찐빵
근데 잘못 끼워서 에러 생기면 어떻게 하죠???????
석두
내장용 인터넷에서 구입 가능하고요. 교체할 기기 배선 잘 기억해 놓았다가 그대로 부착하면 됩니다. 콤보드라이브는 CD는 읽고 쓰고 지우고 쓰고가 되며 DVD 는 오직 읽기만 합니다. 슈퍼드라이브는 DVD 읽고 쓰고 가능한것이고요. 소니, 엘지 , 를 많이 구입합디다.
